Fax
Devonian
Fax
Ok, I know faxing died with the 90's, but I need to fax some invoices and P.O.D for work now and then from February.
Will the cost be charged, or would it come out of any inclusive minutes?
It's an 01 number.
Thank you Plusnet people.
2 REPLIES 2
adamwalker
Fixes: 217
Re: Fax
Hi Devonian,
Essentially the fax machine makes a phone call so as was the case back in the "good" old days of dial-up internet it's charged at the same rate as a phone call so it should be covered by any inclusive minutes.
 Adam Walker
Devonian
Re: Fax
Thanks Adam. Smiley
And now my pager...  Grin
(that's a joke btw)
