Faulty line plus net
- Home Phone
- Re: Faulty line plus net
26-12-2017 6:32 AM
I cannot make calls to anyone. As. It records. What u. Are saying and then rings them back
26-12-2017 8:09 AM
Welcome to the forum.
Something is obviously wrong, but from your description it's hard to think what it might be.
The following information may give some clues -
Do you hear a dialling tone before starting a call?
Are you receiving calls?
Do you hear any recorded announcements, and if so what do they say?
Is your telephone line rental paid to Plusnet or another provider?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
26-12-2017 10:43 AM - edited 26-12-2017 10:48 AM
Normal ring tone.
Then 1571. Person. Comes on with. The person u called is on the phone
if the. Person answers it it records what. Your. Saying. And then rings them. Back. Could you. Plz look into this as soon As possible
cause it leaves me with no landline to get a dr
26-12-2017 10:49 AM
It is. Not fixed
26-12-2017 12:04 PM
Moderator's note:
I have removed the fix.
Forum Moderator and Customer
26-12-2017 1:52 PM
Welcome to the community forums @Honey7
Testing your line isn't finding any issues. Do you experience the same problems with dialling a different number?
26-12-2017 1:55 PM
Yes
26-12-2017 1:56 PM
Can you run through the checks here?
