Faulty line plus net
Honey7
I cannot make calls  to anyone. As. It records. What  u. Are saying and then rings them back
7 REPLIES 7
198kHz
Fixes: 41
Re: Faulty line plus net
Welcome to the forum.  Smiley
Something is obviously wrong, but from your description it's hard to think what it might be.
The following information may give some clues -
Do you hear a dialling tone before starting a call?
Are you receiving calls?
Do you hear any recorded announcements, and if so what do they say?
Is your telephone line rental paid to Plusnet or another provider?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Honey7
Normal ring  tone.
Then  1571. Person. Comes on  with. The person u called is on the  phone
if the. Person answers it  it records what. Your. Saying.  And  then  rings them. Back.  Could you. Plz look into  this as  soon    As possible
cause it  leaves me with no  landline  to get a  dr
Honey7
It is. Not fixed
Mav
Fixes: 515
Moderator's note:
I have removed the fix.
Forum Moderator and Customer
Fixes: 1,600
Welcome to the community forums @Honey7
Testing your line isn't finding any issues. Do you experience the same problems with dialling a different number?
Honey7
Yes
Fixes: 1,600
Can you run through the checks here?
