Faulty Landline
Tess1
Faulty Landline
I share your pain.  Yet again, we have a fault in our village.  (Phones have engaged tone and no service.)  The phone number for fault reporting does not seem to be receiving messages from mobile.  I do not want to join twitter.  My mobile at home gets poor reception.  Why can't I report fault by email?  I tried joining the forum but shouldn't have to do that to report a fault.
I do hope you got your problem sorted out.  The stress is not good for our health.
Luckily, some of the people on the same fault loop (it keeps on happening) are with BT and will get some attention.  I was told by a Plusnet representative that BT customers do not get priority service.  They do in our area.  Despite reporting faults first, our neighbours get an engineer before us every time!
7 REPLIES 7
adamwalker
Fixes: 223
Re: Faulty Landline
Hi @Tess1 I'm really sorry about the issue with your line. I've sent you a PM, can you send me a reply with your username when you can please?
 Adam Walker
Tess1
Re: Faulty Landline
Hi Adam
When I try to reply to your message, I get an "Oops" message:
You do not have sufficient privileges for this resource or its parent to perform this action.
Click your browser's Back button to continue.
Tess
RealAleMadrid
Fixes: 68
Re: Faulty Landline
@Tess1 If you try again it may work, if not send a few more posts. You have to have sent at least 3  but maybe 5 posts to have permission to send a PM
Tess1
Re: Faulty Landline
Thank you Real Ale.  I am not used to forums and it seems an elaborate way to get help.
Tess1
Tess1
Re: Faulty Landline
My box now says that I have no private messages.
Tess1
RealAleMadrid
Fixes: 68
Re: Faulty Landline
@Tess1  Don't know what's happened there.  But you should be able to send a message now, click on @adamwalker's name in his earlier post then on the right hand side below the contact me heading is the send a Private Message button.
Plusnet support used to be easy but they have taken the useful methods away, so now it is hard work.☹️
Tess1
Re: Faulty Landline
Thank you so much for your patience and courtesy Realalemadrid.
Have managed to message Adam now.
@Tess1
