Faulty Landline?
Katydee
Faulty Landline?
My phone won't accept incoming calls and says 'line is in use' when attempting outgoing calls.  Anyone have any ideas?
2 REPLIES 2
Fixes: 383
Re: Faulty Landline?
@Katydee Welcome to the forums. What happens if you unplug the cable from the socket, wait five minutes or so, then plug it back in? Also, check all cables are firmly in sockets.
If that doesn't work, all you can do is report a phone fault - see https://www.plus.net/help/phone/
LaurenB
Fixes: 131
Hiya @Katydee, thanks for getting in touch. I am sorry for the issues with your service and inconvenience this is causing. I have tested the line and this hasn't detected any faults.
I have created a ticket here with the next steps for you, if you let us know once you have added a reply, we will pick that up for you: https://www.plus.net/wizard/?p=view_question&id=219924815
 Lauren Barry
