Fault waiting to happen
the_groundsman
Hi I would welcome some advice please.
My phone and broadband  are working fine at the moment. However I noticed the other day something looked odd with the drop wire from the pole across the road, to my house so took some photos with a zoom lens ( see attached).
The wire seems to have split but its still held by the steel cables inside. I feel sure that there will be trouble soon enough. Would Openreach be proactive and repair this now or do i have to wait for the line to fail and be without phone and broadband. I live out in a rural area so mobile phone and data is patchy to say the least - usually non-existent.
3 REPLIES 3
Re: Fault waiting to happen
Assuming the loop is facing downward that's a great place for water to gather then freeze and this will only serve to exacerbate the issue, but I have a feeling you'll need to wait on a failure before it's fixed.
Beyhive
Fixes: 44
Hi @the_groundsman,
Yes I am afraid we cannot raise it as a fault unless it is service affecting which it isn't from what I can see.
Please let us know if anything changes so we can raise it to our suppliers for you.
 Faris
Kdog
Fixes: 9
You could report it direct to openreach now
https://www.openreach.com/help-and-support/damage-health-and-safety
Theres a form and a phone number there depending on your preference
