Fault service inaccessible
jhv
My phone has been down for two days, yesterday I initially ot through to the fault line on my mobile, but I was on a train and could not pick the reply up. Today they appear to be ghosting me. The numbers I called yesterday now go straight to Call ended.
16 REPLIES 16
Fixes: 357
Re: Fault service inaccessible
What numbers were they? The support number os 0330 123 9123
jhv
The numbers I had were all 0800 numbers, as on advice page. However the number you gave me behaves in the same way. I call it and immediately get the message Call ended.
Fixes: 357
Although the 0800 numbers should still work, the number I gave is the now correct one for support. I've   just tried it and it works for me, so I've no idea what is happening for you.
jhv
And this wasn't happening yesterday btw.
Not sure if I should start a new thread for the actual problem, which is that my home phone has a kind of growl instead of a dial tone and when I try to ring out get the message 'Please wait a moment while we check your line. The order against your line has not been completed. Please try again in a short while.'
I can live for a few days without a home phone, but not without associated broadband.
jhv
I have no idea what the order might be
Fixes: 357
Is this a new connection, or one that has been in place for a while?
Are you saying your BB is also down?
jhv
I've had it for about a year, before that I was a John Lewis customer. Yes, my router is just showing orange. I've tried turning on and off and doing a pint reset, but nothing works.
jhv
Pin not pint!
Fixes: 357
So, you have an OpenReach network issue - although the 'order' comment above is strange. I would do an automated fault report via: https://www.plus.net/help/report-a-problem/
jhv
That link just takes me back to the page with the numbers for text reporting and those numbers seem to be blocking me. Or at least they end my call as soon as I make it. I did talk to a person briefly yesterday, who may have reported an OpenReach issue, but I was not at home to do tests and did not ring her back. My fault, but not a ghosting fault I think.
Fixes: 357
@jhv Very strange, but unfortunately I can't test them for you - I am no longer with PN.
@MatthewWheeler  - can you assist?
jhv
I can't quite believe this, but I seem to have a coincidental fault with my (Vodafone) mobile, or have pressed the wrong button at some point. All calls I make from my mobile are going straight to Call ended. So apologies, it is my phone, not the fault line numbers. I'd still be very grateful if someone would pass on a message to OpenReach about the fault on my line, as I don't know how else to reach them.
Fixes: 357
Unfortunately, it is not possible to 'pass a message on' - you need to contact PN, or use the fault 'bot'. Do you know anyone else with aphone - the cal can be made from any number - it does not have to be your own?
willcutforth
Fixes: 113
@jhv I can see you've contacted us over the phone. If you need anything else please let us know.
 Will Cutforth
