Fault on phone line
- Home Phone
- Re: Fault on phone line
Fault on phone line
17-10-2016 10:19 PM
We have nothing on our telephone line so I have been through the process of running the line checker. Since I got 'Oops, something seems to have gone wrong' and I should telephone the 0800 number. Since I have no phone and customer support is closed until 07:30 I ran the line checker again and then once more just to be sure.
I have just received notification by email that there is a fault external to my premises and it should be resolved in 1-3 days...the only problem is because the web page returned an 'Oops, something seems to have gone wrong' I received the same email 3 times with 3 different reference numbers.
Perhaps if the return on the web page was more informative and not tell me something had gone wrong, this would reduce the number of false tickets being raised.
Regards.
17-10-2016 11:26 PM
I think this is a glitch on their side - once you raise a fault, if you repeat the process it gets confused and gives you an error. But the initial email means that at least one report got through and is being dealt with
18-10-2016 7:11 AM
I could fully understand that but I received the 'Opps.....' error on my first submission as well so this is not explained by a 'glitch' due to multiple submissions.
18-10-2016 1:16 PM
Sorry that the test produced a non-meaningful error for you, the fault was reported to us. I can see we passed this to Openreach and have been advised an engineer fixed a fault in the network today. Are you still having the same issues?
18-10-2016 1:26 PM
I can confirm my phone once again has a line connected to it and is therefore working.
Less than 24 hours to fix, good service, well done and many thanks.
19-10-2016 2:01 PM
