Fault located between DP and customer apparatus
- Home Phone
- Fault located between DP and customer apparatus
08-09-2016 4:14 PM
Hi
I have just logged an issue with my phone as have no dialling tone - have line cord error.
Plusnet have completed checks and emailed me to say 'fault located between DP and customer apparatus.
Sorry for sounding daft but what does this mean in simple terms? General fault on the line? x
Re: Fault located between DP and customer apparatus
08-09-2016 9:34 PM
@Madron - Well my guess would be that DP either means distribution pole or point and the customer apparatus would I suspect be the master socket in your house. With that said it could be a breaking wire or bad connections, so I hope that helps.
09-09-2016 8:40 AM
So it could be anywhere between the phone and the exchange? I had all this sort of ambiguous palava when they investigated my phone line fault. Confused? So where the many BT 'engineers'.
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
09-09-2016 8:46 AM
@Minivanman - So you're thinking that the 'customer apparatus' is in the exchange then and not the master socket, that kind of makes sense I guess.
09-09-2016 8:50 AM
Thank you everyone for your replies.
@Anonymous, if it were a problem with the master socket, would there not be a problem with my internet connection as well? I am connected to a router and don't have any problems with connecting to the internet. Hopefully will find out soon! xx
09-09-2016 9:02 AM
@Madron - Ah! well until @Minivanman mooted the idea that the customer apparatus could be in the exchange I did think it might have included your master socket and what was connected to it. Taking the term customer apparatus literally would mean stuff that belonged to you, and as you don't own anything in the exchange...
09-09-2016 9:07 AM
I never said that the customer apparatus was the exchange Mook, where did you get that from?
Herman Melville
09-09-2016 10:52 AM - edited 09-09-2016 10:53 AM
@Minivanman - No you didn't, I simply misunderstood your post.
09-09-2016 10:57 AM
Thank you.
Herman Melville
- Home Phone
