Fake numbers in 1471 from scammers
hitchhiker43
Fixes: 4
This seems to be the latest game to get around call blockers etc, I just had a recorded PPI call and as usual did 1471 after I cut it off to get the number for the ICO, it was 01956 42355 one digit short! (UK landlines are 11 digits) so these [-Censored-]s are somehow spoofing the number they are calling from even though its a landline ?Huh
Shouldn't the phone providers be doing something about this as it defeats some means by which we poor customers use to detect and ignore fraud calls ?
Tp-link W8960n on longgggggggg line!
4 REPLIES 4
Darkfire
Fixes: 30
Re: Fake numbers in 1471 from scammers
Hi Hitchhiker,
whilst these calls are most definitely annoying(I don't even own a handset for this reason), that number is a real number, UK numbers can be 10 or 11 digits Smiley
hitchhiker43
Fixes: 4
Ohh thank you I didn't realize that, several look up sites reported it as fake on the basis of not being 11 digits, well I reported it to the ICO anyway (not that I am sure that does anything except keep there server busy)!
198kHz
Fixes: 40
@hitchhiker43  @Darkfire
True - UK numbers can be 10 digits i.e. five digits after the area code.
However, in this particular case, it's definitely a spoofed number, as 01956 is not a valid code, as can be checked on the BT website.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
MauriceC
Fixes: 17
As an additional observation:  Most of these 'spoofed' calls I've had in the last few weeks are carefully crafted to look like one of your well known local prefixes - so a quick glance at the displayed number makes you woonder if is a local call?
M
