Ex-Directory
ming
Ex-Directory
We are ex-directory with BT and we change over to Plusnet on Tues. Was just wondering when I read some posts about nuisance calls - will we stay ex-D when we change over? As my OH is quite ill and sleeps a lot and I totally HATE stupid phone calls that wake him up or disturb him.. ?
11 REPLIES 11
Strat
Fixes: 565
Re: Ex-Directory
It might be worth raising a ticket to emphasise the request.
orbrey
Re: Ex-Directory
When you migrate a phone service across it's done on a like for like basis, so you should remain ex directory following the move.
Hope that helps,
ming
Re: Ex-Directory
OK MANY THANKS !  Wink
binzy
Re: Ex-Directory
hi guys
              well when i did the same thing a couple of years ago i lost my ex-directory i had with bt and now im getting all sorts of greef  just read my post Nuisance Calls
                                    binzy
Bud
Re: Ex-Directory
Being Ex Directory has nothing to do with not getting any of those random calls, or companies calling you up.  Being registered with the TPS helps, but wont stop any of the overseas calls.
Ellis
Re: Ex-Directory
Nuisance calls are not stopped by being XD. The only way that I know of guaranteeing that you don't get nuisance calls is for your line to be outgoing only, but then no one can call you. You could use a mobile phone for receiving calls, but it might not be very popular with your friends.
Strat
Fixes: 565
Re: Ex-Directory
Quote from: binzy
Which is why I suggested raising a ticket as a belt and braces method.
pennbank
Re: Ex-Directory
You can always check here
http://www.btexchanges.com/
anniesboy
Re: Ex-Directory
I am ex directory ,I changed from BT to P Net in January , I have had no such calls.
I have been ex directory for all the time Ive had a phone,also registered with TPS.
peter10
Re: Ex-Directory
I changed my phone to Plusnet in September. I was ex-directory with BT and have never appeared in the paper directory sent out to homes. After change over I checked the BT online directory and I was listed. I am not sure how long I had been there. Could be worth checking after transfer. Raising a ticket soon had my name removed.
The_10th
Re: Ex-Directory
Bit of a HJ but if one is on the BT Privacy service is this transferred too and is it just BT putting your details on the TPS http://www.tpsonline.org.uk/tps/index.html?
