Engineers cause my phone to be down at this most critical of times
- Home Phone
- Engineers cause my phone to be down at this most c...
24-12-2018 11:58 AM
On contacting plus.net I was told that the fault would be rectified by 28th Dec.
Totally unacceptable..Going to change to someone that will "DO ME PROUD"
Re: Engineers cause my phone to be down at this most critical of times
24-12-2018 12:15 PM
Hi @wrinklie1
Thanks for getting in touch. I'm sorry to hear that you're experiencing a fault.
I can see that my colleague raised this to our suppliers for you this morning, here.
I'm sorry that you feel that a resolution time of four days during the festive period is unacceptable. As I'm sure you can appreciate, many businesses, including Openreach are closed over Christmas. The normal minimal turnaround for a fault is 2-3 working days. As Christmas Day and Boxing Day are both bank holidays, I'm not at all surprised or concerned that the earliest resolution date for your fault is 28/12/18 - it's unfortunate that a fault has occurred so close to Christmas but the lead time you've been provided is reasonable given that tomorrow is Christmas Day.
You are of course entitled to change providers should you feel this is appropriate, however, you will find that the majority of UK ISP's use the BT Wholesale network and therefore would be subject to the same engineer timescales and availability.
My colleagues will be monitoring the fault and will provide updates via the ticket I've linked above accordingly.
Best wishes
Dave
24-12-2018 4:24 PM
m delighted to advise that the fault has now been corrected. So someone "DID ME Proud.
- Home Phone
