Enabling voicemail
wrinklie1
Enabling voicemail
I have searched and searched all over this site with success.
Will somenone please tell me how I enable this feature P L E A S E
4 REPLIES 4
MymsMan
Re: Enabling voicemail
See https://www.plus.net/help/phone/call-features/
Open the How Do I Use tab and scroll down to the Voicemail section
198kHz
Fixes: 41
https://www.plus.net/plustalk/index.php?page=wlr_add_call_features
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
MasterOfReality
Fixes: 57
Hi @wrinklie1
Standard Voicemail comes with all our phone packages, we add it automatically when you sign up, unless you tell us not to.
Using Voicemail:
To access the main Voicemail menu- Dial 1571
To check your messages - when you hear the main menu, press 1 to start playing your messages
  • Press 0 to return the call
  • Press 1 to replay the message
  • Press 2 to save it
  • Press 3 to delete
  • Press 7 to rewind a few seconds
  • Press 8 to pause or play
  • Press 9 to fast forward a few seconds
To record a new Personal Greeting - When you hear the main menu, press 2 to go to Personal Greeting and then 1 from the next menu
Press 1 again and when you hear the tone, you're ready to start recording
When you're done, press #
  • Press 1 to listen to the message you've just recorded
  • Press 2 to use it as your Personal Greeting
  • Press 3 to re-record it
  • Press * to delete it and carry on using the message you had before
To use the standard Personal Greeting - When you're on the main menu press 2
Press 2 again to use the pre-set standard Personal Greeting.
Hope his helps.
MoR
wrinklie1
many thanks  sorry for delay in reply
