Early transfer to VOIP on upgrade to Full Fibre
prdixon
My current Fibre broadband and phone line rental contract ends in June 2025. I would in principle be happy to upgrade now to Full Fibre, but would lose the landline. I want to keep the landline number. As Plusnet are not offering VOIP, I would probably transfer to a separate VOIP provider like Voipstudio and get the number ported across.
However, the timing seems awkward. Would I have to sign up to Voipstudio in advance of changing the Plusnet contract, so as not to lose the home phone number? And would Plusnet allow the number to port away from them before the end of contract? Or is it simply a matter of continuing to pay the line rental to the end of the contract period?
Thanks!
13 REPLIES 13
Fixes: 334
Re: Early transfer to VOIP on upgrade to Full Fibre
Your phone number is 'quarantined' for 30 days after the transfer to Full Fibre, so you would have time to transfer it once the FF was up and running.
Note, however, that most VoIP  providers have problems transferring a 'ceased' number.
Fixes: 530
@prdixon
No, you need to upgrade to Full fibre first. That will cease the phone service, you then have 30 days to port the number to a voip supplier before its lost.
If you port the number before changing to Full fibre then it will cease your existing broadband,
You can upgrade to full fibre before the end of the existing contract and then port the number as above
Fixes: 89
@prdixon
With FTTC your PN account is controlled by the phone line. Transfering your phone will lead to the account being cancelled plus early termination charges.
As stated you need to upgrade to FTTP first and once this is complete you have 30 days to "port" the phone number.
Sone VOIP providers (like A&A) will allow you to set up an account in advance with a new number so you can ensure your phone works with VOIP. Then, when FTTP is installed you port your original phone number in. With A&A you then cancel the other phone number. This also gives you a working phone during the porting of you old number.
markhawkin
All Star
Fixes: 19
@prdixon
I spoke to a VoIP supplier to check that they understood the need to retrieve a quarantined number and selected the supplier on their response to that question (they absolutely "got it").
I then set up the VoIP service on a temporary number, got it all working and then ordered the Plusnet full fibre upgrade.
Once I had a date for the full fibre install, I requested the landline number "port" for the next working day and it all went smoothly.
I don't think the landline was out of service for more than a few hours on "porting day" and that was only for incoming calls.
It then took a few months for Plusnet to sort the billing out....
iannewson
Fixes: 5
The easiest way to do it with minimum downtime is to have FTTP installed as well as your current connection. Once you are happy the FTTP is running ok then port your number out (which will cease your current connection). This will result in minimum downtime. Only drawback is you have two connections for a brief period of time. This is what I did.
Fixes: 237
The downside of that approach is that it requires a new Plusnet account … which if the existing account has email and / or a static IP address, both will be lost with the suggested tactic.
prdixon
Thank you all so much for the rapid-response helpful answers to my question. This gives me a way forward and removes the time pressure.
Peter
CPH2012
Which VOIP provider did you use please
Fixes: 237
UPDATE: A note of caution - if the plan is to keep broadband with Plusnet (SoGEA or FTTP), though the new service might be active, do not initiate the voice service transfer until the service change confirmation email is received from Plusnet.
iannewson
Fixes: 5
Personally I used Andrews and Arnold (AAISP) for my VOIP.
prdixon
I'm not quite that far along the road, CPH. Still considering options.
klyne
I am sure I read somewhere that BT were having second thoughts about elements of their major reorganisation? I assume this has not included allowing Plusnet to offer a VOIP service? Or can I live in hope?
David
prdixon
Many thanks to Townman and several other who helped me tiptoe through the minefield of transferring residential phone to VOIP without losing the landline number. I thought I might give some feedback on how it went. The process completed today and your advice on getting things in the right order was critical. I upgraded my Plusnet broadband to fibre (not yet Full Fibre in my area), which cancelled the phone contract, and porting the phone line took five days. So we weren't able to receive calls on the old number for that short period.
I investigated more or less the whole range of VOIP providers, including A&A, Vonage, Voipstudio, Voipfone etc, but eventually settled on Phonely. In terms of monthly charge, they are far from the cheapest (£10/month including 800 UK minutes, or £15 / month with their security/ anti-phishing add-on), but their call rates for international calls seemed more reasonable than others - important for me with relatives in Australia. If you pay a year in advance, they include the £50 VOIP adapter. Of course, you can get free overseas calls through services like Whatsapp, but they seem to drop out quite frequently and frustratingly. As important for me was Phonely's supportive approach to the transition for residential customers, including helping get the details right on the porting form.
Thanks again to all who gave advice - it definitely helped me smooth the process!
Moderator's note(s):
Promotional link for personal gain removed as per Forum Rules.
