Downloading itemised phone calls
crunchie1
Browser
I am a new user of the phone service. Is it possible to download my itemised phone calls in csv or text fiormat so that I can import them into a spreadsheet?
3 REPLIES 3
Oldjim
Fixes: 63
Re: Downloading itemised phone calls
Even better - you can download them as a csv file https://portal.plus.net/plustalk/index.php?page=wlr_itemised_billing&view_bill_date=
See near the bottom
You can also change the date period and download those as well
robin_newcastle
Browser
The previous reply mentioned that you can set the start / end date for the tiemised csv file - I cant see a way of doing that - you need to download each month at a time - very poor design
PeeGee
Depends Shocked The csv files are linked to the billing dates and, possibly, are mostly used for checked the billing in the way bank statements are used. I don't find that poor design but rather logical.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
