Does Plusnet activate phone lines?
- Home Phone
- Does Plusnet activate phone lines?
09-02-2013 11:22 AM
Hi
My house has 2 phone lines, one of which was deactivated some years ago. As Plusnet take care of my phone bills now I am wondering whether Plusnet can also activate my old line should I wish to do so. If yes then what costs are involved?
Regards
Mark
Regards
Mark
Message 1 of 7
(1,359 Views)
6 REPLIES 6
Re: Does Plusnet activate phone lines?
09-02-2013 11:33 AM
Yes - BUT - normally only as part of a broadband order
Message 2 of 7
(497 Views)
09-02-2013 11:34 AM
Ah ok. Sounds like I need to approach BT then.
jim:quote
jim:quote
Message 3 of 7
(497 Views)
09-02-2013 11:40 AM
You could try ringing them - they may play ball
Message 4 of 7
(497 Views)
09-02-2013 11:43 AM
Ring who? You mean Plusnet? BT will activate it obviously. Just easier to ask Plusnet to take over and sort it out.
Message 5 of 7
(497 Views)
09-02-2013 11:47 AM
Plusnet and explain the situation or wait until it is picked up on Monday here
Message 6 of 7
(497 Views)
09-02-2013 11:53 AM
Ok. Sounds like a plan :). Could raise a ticket I suppose. Might as well.
Message 7 of 7
(497 Views)
- Home Phone
