Does Call Protect actually work?
- Home Phone
- Re: Does Call Protect actually work?
22-05-2017 6:16 PM
Since enabling Call Protect on my line I have been receiving FAR MORE junk calls than I did without it active so does it actually work? Junk calls are coming through to my normal 1571 voicemail box as well with dialing 1572 and selecting the option to listen to the junk mailbox going to a continuous beep.
Not impressed with it so far....
24-05-2017 8:30 AM
Works OK for me. Since setting it up:
No more "International" calls. A few number of "marketing research" calls which I then immediately blocked and after a month I don't think I've had one for a week now.
24-05-2017 11:03 AM
I'm not sure how it can alter the number of spam calls you receive, have you been able to add them to the spam list?
24-05-2017 12:39 PM - edited 24-05-2017 12:42 PM
The day after activation the junk calls have doubled (which must be a coincidence), tried to add them to the spam list but because they have ended up leaving voicemails on 1571 you can't add the last caller as its not classed as answered.
I will have to have a play around with the settings and try blocking overseas calls once I can add the family numbers to the VIP list, but it doesn't tend to be international calls that are the junk ones.
24-05-2017 3:21 PM
I used 1572 Option 1 to put the last call into the block list.
24-05-2017 5:50 PM
Like I said, if the call has gone onto the 1571 voicemail you can't use the 1572 option 1 to add it to the blocked list as its not deemed to have been answered.
24-05-2017 6:33 PM
It won't accept some odd overseas numbers, such as one I had recently:
06113 000123
- Home Phone
