Diverted calls to mobile
jmane24
Hi I have now set up a call feature to divert calls to my mobile, however I cannot see any option to input the actual mobile number you want the landline to be diverted to.
Can you advise please?
1 REPLY 1
198kHz
Fixes: 40
Re: Diverted calls to mobile
Using Call Divert
Setting it up is just that - setting up.
To use it, you have to enter codes and the number on the phone you're diverting from eg
There are three codes you can use, depending on what you want to do:
  • 21 diverts all calls
  • 61 diverts calls you don't answer in 15 seconds
  • 67 diverts calls when you're on another call
If you want to... Here's how you do it
Set up Call Divert Press *(Code)*(Number to divert to)#
Check Call Divert Press *#(Code)#
Turn off Call Divert Press #(Code)#
From https://www.plus.net/help/phone/call-features/
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
