Divert Landline
amyk01
Divert Landline
I have tried diverting my landline using the *21* codes, but it is saying it is not available on my line. Can someone please help as i really need to divert calls for my business
Many thanks
6 REPLIES 6
198kHz
Fixes: 42
Re: Divert Landline
Welcome to the forum.  🙂
Have you opted for the feature via Member Centre >> Phone >> Call Features ? (£2·50 per month).
BT technician (Retired)
LaurenB
Fixes: 131
Re: Divert Landline
Hiya @amyk01, thanks for getting in touch. I'm sorry for the problems you've had with the feature. I realise it's been a few days since you posted, is this now sorted?
 Lauren Barry
amyk01
Re: Divert Landline
No - I added the call divert feature. Diverted my phone and it worked.
I then got an email saying it had been removed and none of my calls have diverted for days. I am trying to run a business and I have missed a number of calls. I’m completely appalled at this rubbish service.
amyk01
Re: Divert Landline
It is absolutely unacceptable. If this is not sorted and plusnet are unable to keep a phone diverted I will change and go with another provider I am paying for a service I am not getting.
pjmarsh
Fixes: 24
Re: Divert Landline
Your quickest way would likely to give the Business Support Team a call on 0800 028 0282.  They are available 24/7.
LaurenB
Fixes: 131
Re: Divert Landline
Hiya @amyk01, I'm sorry to hear the feature was unexpectedly removed and for the problems this has caused you. It's not the experience we want you to have at all!
I have provided a more detailed response on your account here: https://www.plus.net/wizard/?p=view_question&id=227147702 where you're able to add a reply.
 Lauren Barry
