Disable 1571, please
- Home Phone
- Re: Disable 1571, please
26-10-2015 10:44 PM
I see a number of posts on this topic...
I'd rather not have 1571 activated on my account, so if it can be disabled, please, I'd appreciate it.
If you're looking to give away free calling features, how about replacing 1571 with Caller Display as a freebie instead?
Message 1 of 7
(1,311 Views)
6 REPLIES 6
26-10-2015 11:03 PM
Hi
You can disable voicemail in the phone control panel in the member centre, should be gone by morning if you do
Message 2 of 7
(654 Views)
27-10-2015 7:58 AM
No, you can't. That's why I posted here.
Message 3 of 7
(654 Views)
27-10-2015 12:02 PM
Your line doesn't seem to have 1571 enabled on it? I've checked our system and the Openreach side and voicemail is not active.
Message 4 of 7
(654 Views)
27-10-2015 11:59 PM
<panto>Oh yes it is...<panto />
Message 5 of 7
(654 Views)
28-10-2015 11:39 AM
Oh no it's not.
In all seriousness, if you dial 1571 do you get the voicemail options as it's showing off completely on the wholesale systems too.
Message 6 of 7
(654 Views)
29-10-2015 7:56 AM
"This line doesn't have a call answering service"...
D'oh! Never thought to check it, I was just going by what it said in the CP.
So, although I don't want or need it, I don't really have it. C'est la vie...
Message 7 of 7
(654 Views)
