Directory Enquiries- any cheap versions recommended ?
- Home Phone
- Directory Enquiries- any cheap versions recommende...
01-04-2008 8:12 PM
Recently moved to HomePhone.
My wife dialled 100 for dirctory enqs. (i.e.118500) without me knowing, and it cost me 78p. for 1 min !
Can anyone recommend a reliable, cheaper number to use in future ?
Message 1 of 6
(2,502 Views)
5 REPLIES 5
Re: Directory Enquiries- any cheap versions recommended ?
01-04-2008 8:15 PM
This is free http://www.bt.com/index.jsp
You may need to use advance search to cut down the results
Message 2 of 6
(616 Views)
01-04-2008 8:27 PM
the actual BT directory is free on Internet the free one
Message 3 of 6
(616 Views)
01-04-2008 8:39 PM
This from the Money Saving Expert site is well worth a read.
Message 4 of 6
(616 Views)
01-04-2008 8:44 PM
If you are looking for a "local number" say , " fitness centre" Margate (or where you live) and you know the name, if you just google for it, you could find the phone number is also listed.... if you "google maps" it, you will get the alternatives too !
EDIT....
And make sure you have this http://www.saynoto0870.com/
in your Favourites/Bookmark list...... useful for alternative numbers not on high rates...
Surprising how many have "ordinary" phone numbers that you can call.....
EDIT....
Message 5 of 6
(616 Views)
01-04-2008 9:28 PM
Thanks to everyone for the various replies, all noted and logged, super ideas !
Message 6 of 6
(616 Views)
- Home Phone
