Directory Enquiries- any cheap versions recommended ?
- Home Phone
- Re: Directory Enquiries- any cheap versions recomm...
01-04-2008 8:12 PM
Recently moved to HomePhone.
My wife dialled 100 for dirctory enqs. (i.e.118500) without me knowing, and it cost me 78p. for 1 min !
Can anyone recommend a reliable, cheaper number to use in future ?
Message 1 of 6
(2,498 Views)
5 REPLIES 5
Re: Directory Enquiries- any cheap versions recommended ?
01-04-2008 8:15 PM
This is free http://www.bt.com/index.jsp
You may need to use advance search to cut down the results
Message 2 of 6
(612 Views)
01-04-2008 8:27 PM
the actual BT directory is free on Internet the free one
Message 3 of 6
(612 Views)
01-04-2008 8:39 PM
This from the Money Saving Expert site is well worth a read.
Message 4 of 6
(612 Views)
01-04-2008 8:44 PM
If you are looking for a "local number" say , " fitness centre" Margate (or where you live) and you know the name, if you just google for it, you could find the phone number is also listed.... if you "google maps" it, you will get the alternatives too !
EDIT....
And make sure you have this http://www.saynoto0870.com/
in your Favourites/Bookmark list...... useful for alternative numbers not on high rates...
Surprising how many have "ordinary" phone numbers that you can call.....
EDIT....
Message 5 of 6
(612 Views)
01-04-2008 9:28 PM
Thanks to everyone for the various replies, all noted and logged, super ideas !
Message 6 of 6
(612 Views)
- Home Phone
