Dial tone gone strange today not constant like it should be
- Home Phone
- Dial tone gone strange today not constant like it ...
06-03-2013 12:42 PM
The phone does not seem right today, the dial tone is not constant anymore but was ok yesterday.
only way i can explain it on here would be like this
beep stop beep stop beep stop not a constant dial tone like it should be.
Is someone messing with my line?
I can make calls but i wont be making any while it has this odd thing going on.
Message 1 of 5
(9,854 Views)
4 REPLIES 4
Re: Dial tone gone strange today not constant like it should be
06-03-2013 12:43 PM
It probably means that you have a voicemail.
If you dial 1571 you should be able to retrieve it.
Message 2 of 5
(4,832 Views)
06-03-2013 12:53 PM
Thanks for the fast response, Does it cost anything to retreave the voicemail?
I think i will turn this feature off to as we have an answer machine on the phones and the rest of the family i used to using it this way.
Message 3 of 5
(4,832 Views)
06-03-2013 12:53 PM
No, it's free.
Message 4 of 5
(4,832 Views)
06-03-2013 12:55 PM
Thanks James
it was a voicemail but the family are just not used to them as we have answer machine on the phones so i have decided to disable the feature
Message 5 of 5
(4,832 Views)
- Home Phone
