Dedicated number for L/line phone faults
glloyd
I note there is a dedicated phone number for mobile phones. Isn't about time there was a dedicated number for L/Line faults.
5 REPLIES 5
Chris
Legend
Fixes: 169
Re: Dedicated number for L/line phone faults
The number for this is the normal support one, but choosing the relevant options as you go through the menu.
glloyd
There is no dedicated option for phone faults so you have to get on the queue with all other faults which can take an hour and same with the chat if it's working.
HarryB
Fixes: 255
Phone faults and broadband faults are dealt with initially by our tech support team and then on to our faults team if not resolved in the first instance by tech.
Creating another pathway would ultimately mean they still go through to the same department.
 Harry Beesley
 Plusnet Infrastructure Operations Professional
glloyd
So if your phone goes down how do you report it? Go round knocking at doors and ask if you can use their phone for a hour or more. You make enough money out of line rental to have a dedicated number and agent. If it'd s good enough for your mobile service customers who do not pay high L/Lines charges it's should be good enough for the L/line phone users.
HarryB
Fixes: 255
The same way you would with a dedicated line for raising phone faults as it would still go through to the same set of advisors.
I appreciate the thought behind it, and I'm more than happy to pass your feedback on, however I don't believe creating another pathway directly over another number, as opposed to going through the IVR is the solution.
I agree call queues need to come down, but introducing another pathway in would unfortunately not fix this.
 Harry Beesley
