Credit!!
penfold
Fixes: 5
Credit!!
Just signed up to the anytime+ product, and one of the E-Mails I have received says I have £70 credit available. Can anyone expand on this at all, or is it just down to my inclusive call time I will have?
12 REPLIES 12
paulby
Re: Credit!!
The credit limit is there as a means of protection so that you don't run up huge bills unexpectedly (BT & TalkTalk also give you a credit limit for calls).  It's NOT a PAYG phone service - you will get billed for calls and your credit will revert back to £50 or £70 the next month.  If you do make more than £70 worth of calls in a month you can up your limit although you'd really have to be going some to make that many chargeable calls on the Anytime+ package!
Oldjim
Fixes: 63
Re: Credit!!
Rather than start a new thread -
I have just signed up for home phone anytime+ so can't check yet but can the credit limit be reduced as virtually the only chargeable use would be calls to mobiles and if that goes over £5 per month I will be having words.  Grin
paulby
Re: Credit!!
You can't reduce it in the portal - only increase it by using a credit card.  Don't know if it can be done by Mand "behind the scenes"!
Oldjim
Fixes: 63
Re: Credit!!
If anyone is interested I suggest voting for this item http://usergroup.plus.net/pugit/view.php?id=397
Strat
Fixes: 565
Re: Credit!!
Quote from: Oldjim
I am and I have Jim Smiley
Windows 10 Firefox 107.0 (64-bit)
pierre_pierre
Re: Credit!!
its alright if you are a user group forum member
Oldjim
Fixes: 63
Re: Credit!!
If you aren't it's simple enough to register
paulby
Re: Credit!!
I wouldn't like to see it set any lower by default but, if you want to set a lower limit, then the option should perhaps be made avaialble.
To put PN's limit in perspective, BT set a £150 limit for my account when I signed up, at which point they would phone you (never got anywhere near using £2 of it let alone £150).  When I was with TalkTalk, they set a £250 limit.
Oldjim
Fixes: 63
Re: Credit!!
The part I have a problem with is that the calling plan with the most included has the highest credit limit
What credit limits are in place?
The credit limits on Home Phone accounts are as follows:
Home Phone Evening & Weekends: £50
Home Phone Anytime: £50
Home Phone Anytime+: £70
Now if one was concerned about setting the limit too low and getting outgoing calls bocked this mechanism should stop it providing the costs were incurred over a reasonable period. However if something went wrong then a lower limit could easily stop the rot before it became too expensive.
What if I use up all my credit?
If you reach your credit limit, you will not be able to make outgoing phone calls, except emergency and operator calls.
If we have to stop your outgoing calls, you will be charged a fee of £5.76 to re-enable outgoing calls.
You can stop this happening by topping up your credit limit using a debit or credit card. We will email you to warn when your available credit limit reaches levels of £15, £10 and £5 to help you manage this.
Mand
Re: Credit!!
It's not currently possible to change your credit limit on an individual basis, this is set by the product you are signed up for.
You can effectively increase the credit limit by adding a top-up payment.
I can't sort it 'behind the scenes' either unfortunately.
FWIW the only queries we tend to get regarding the credit limit are requests to increase the limit, not to reduce it.
I'd suggest voting for the PUGIT issue if this is something that there is a demand for, so that we can get this on the project radar. Smiley
Strat
Fixes: 565
Re: Credit!!
Quote from: Mand
Wink
I have a £4500 credit limit on my Visa card. It may as well be £4.5 million for the difference it would make. (I hardly ever use it).
As has been said, the main reason I would have for imposing a call spend limit would be to control my daughter's mobile (particularly Three) and 08 chargeable calls.
Re: Credit!!
I believe this is something Liam asked about before, or perhaps slightly similar.
/goes to look
