Crackling on line
- Home Phone
- Crackling on line
Crackling on line
10-06-2015 11:03 AM
Any further help or advice would be appreciated.
Re: Crackling on line
10-06-2015 12:39 PM
I've conducted some tests, and there may be a potential problem. I've opened ticket 105580375 on your account, which has some checks we need you to do. When you've done them, if there's no improvement, please reply to the ticket, and we can get a fault raised to our suppliers for you
10-06-2015 12:47 PM
10-06-2015 3:16 PM
10-06-2015 5:46 PM
I've just performed a speed test at http://www.supportal-test.co.uk/ and we're only getting 8mb after receiving our usual 37mb speeds since we switched and this morning when I performed a test then. I have entered our telephone number after both tests if you can see them.
Any further help would be appreciated.
10-06-2015 5:57 PM
10-06-2015 6:02 PM
11-06-2015 12:35 PM
Just to add, my download speeds have improved upon the results late last night, but are still way below the speeds we received before with our previous provider and immediately after the switch to Plusnet.
11-06-2015 3:08 PM
11-06-2015 5:23 PM
Thanks for the speedy resolution.
11-06-2015 5:41 PM
