Crackling on Landline
Grhmeh
My phone line is crackling and has been for some time , I bought a new BT Decor 2200 phone but this has made no difference so I unpluged the BT master socket and connected to the internal socket to see if it was better, it made no difference to the crackling. I then found the plusnet line checker ,this said there was a line fault, as I checked with only the new phone connected and I could hear the crackles I can’t see that there is an internal house fault after the BT socket. Is it possible that it could be looked into please.Broadband is working fine.
3 REPLIES 3
Alex
Fixes: 13
Re: Crackling on Landline
Hi @Grhmeh
Try a 17070 option 2 quiet line test too, so you can hear the noise without any dial tone.
Sounds like you are right, and there is a fault outside your property. You'd need to raise this to BT Wholesale.
You've already tried the test socket, so it will be a fault.
This has happened to me in the past. The engineer was very good and did something outside my house and got it fixed in around half an hour.
Legend
Fixes: 219
@Grhmeh To follow from your post and @Alex 's comment, it appears the system has picked up an external fault try checking your open questions in 'My Account' - there should be one which will have been created as a result of your action on the line checker.
198kHz
Fixes: 39
Log into the Member Centre and have a look here -
https://www.plus.net/wizard/?p=search
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
