Crackling Phone line...
- Home Phone
- Re: Crackling Phone line...
02-01-2019 10:16 PM - edited 02-01-2019 10:18 PM
I have tried a couple of phones in my flat (since November) and I assumed it was the old phone that was the issue but I've since bought a different phone and I've still got the same crackling noise issue... it's not a major concern as to be honest I rarely use the landline now but It would be nice to have it working properly
I will report the issue tomorrow, I've tried using the self line check tool on the Plusnet website but it just reports that the result was unclear and to try again later.
One question I do have is that I am in a block of housing association flats and to me the wiring for my phone line looks "interesting" who would be charged if the issue was found to be bad wiring or just old wires inside the flats? I will speak to the HA tomorrow as well to get their take on this if Plusnet tell me there isn't any issue that they can see from a line check
Thank you
02-01-2019 10:33 PM
02-01-2019 10:47 PM
Hi thank you for replying,
I've just taken the panel off and connected the phone directly to the test socket and still get a crackly line, I was unaware that they would cover it right upto my master socket so thats good to know
03-01-2019 10:44 AM
Hi there, I've just tested your line and we're not picking up on any faults so we'd need to arrange an engineer visit to take a look into it for you. It looks like you've just called in and got one arranged with us so I hope that gets the issue fixed.
03-01-2019 3:38 PM
If you get a blue BT Directory at front, there's an illustration of an Master Socket , and location of the Test Socket.
04-01-2019 12:16 AM
I took the cover off and tried the phone directly in the test socket and it's still crackly, I've got an engineer booked for next week
04-01-2019 10:46 AM
09-01-2019 2:34 PM
09-01-2019 3:19 PM
- Home Phone
