Crackle
- Home Phone
- Crackle
Re: Crackle
06-01-2015 4:46 PM
Note that with DECT phones, there is likely to be some back ground hiss.
Re: Crackle
06-01-2015 4:47 PM
Re: Crackle
06-01-2015 9:45 PM
Re: Crackle
07-01-2015 6:52 PM
Re: Crackle
08-01-2015 4:35 PM
Re: Crackle
08-01-2015 5:33 PM
Re: Crackle
10-01-2015 7:24 AM
Re: Crackle
10-01-2015 8:41 AM
Re: Crackle
10-01-2015 9:10 AM
Quote from: mpotter Bumping to ask what the results of this are?
The results of what sorry? I see you've reported a broadband fault to us, however as the phone line is crackling and the dial tone dropping out then we really should get that fixed first.
Our automated testing detected a potential issue on the phone line, so that's the route we'd be going down to get this resolved.
Re: Crackle
10-01-2015 5:42 PM
Re: Crackle
11-01-2015 10:33 PM
Re: Crackle
12-01-2015 11:18 AM
Re: Crackle
06-02-2015 3:40 PM
Re: Crackle
13-04-2015 12:56 PM
Re: Crackle
14-04-2015 11:09 AM
Unfortunately on some lines (especially long rural ones) there can be numerous locations for there to be joint issues, which might not indicate an issue when the engineer visits. In such circumstances, it is essential that it is made clear that the issue is INTERMITTENT and has failed repeated attempts to rectify.
Hopefully that will lead to a request to check every joint and / or find best available d-side & e-side pairs. Lines might also only show faults when tested in one direction - I have seen a line test out OK from the user's premises, but fail when tested from the cabinet to the premises.
