Could memeber of Plunet staff look into this?
- Home Phone
- Could memeber of Plunet staff look into this?
08-10-2009 2:04 PM
At the moment my itemised bill for the phone runs from 22 of month to 21 of following month. Broadband is from 10 of month. Direct debit for both comes off around the 10 of month.
It would make it easier to follow if they were both dated the same. When we moved our phone to plus net we were advised this would update itself but so far it does not seem to have.
Thanks and hope this all makes sense.
Re: Could memeber of Plunet staff look into this?
08-10-2009 2:16 PM
08-10-2009 2:27 PM
08-10-2009 2:42 PM
Hope that helps,
08-10-2009 2:46 PM
Thanks again
10-10-2009 2:24 PM
Quote from: orbrey Right it's actually nearly done - your next billing date for both the phone and the broadband will be on the 10th October, and the talk contract date will sort itself on the 10th too.
Hope that helps,
Hi just to let you know phone date has not sorted it self out
10-10-2009 5:37 PM
10-10-2009 7:11 PM
12-10-2009 9:29 AM
Quote from: Charley
Hope that helps,
Hi just to let you know phone date has not sorted it self outCould you have a look and see why?
Ok its getting very confusing now as I have just paid for calls up to 10 October but they are still showing on my bill as if they have still to be paid? as the phone bill date has not sorted it self out. I'm getting a bit worried I am going to end up paying for calls twice.
12-10-2009 10:04 AM
Keep an eye on your credit limit as this is decremented every time a chargeable call is added to your bill. You're charged on your billing date the amount your credit limit has been decremented in order to bring it back up to £75 on Anytime or £55 on E+W and, because the phone billing and the broadband billing are out of sync, this covers calls across two bills - confusing or what?
12-10-2009 10:24 AM
12-10-2009 1:27 PM
This is now raised as an internal problem (57622), I'm pushing this with the development team and will keep you posted for updates.
12-10-2009 1:41 PM
There does seem to be a lot of us with the same probelm. Hopefully it will be something that can be fixed.
20-10-2009 7:55 PM
Quote from: orbrey Hi Charley,
I just wondering if there is any update on this problem and if there is a time scale on long how it might take to be resolved?
I'm finding my billing very confusing and especially after getting the e-mail advising that I have been under charged. Not that I didn't believe PN but I wanted to check myself and it took ages trying to match up my invoices with my phone calls on itemised billing due to them being out of sync.
20-10-2009 8:07 PM
- Home Phone
