Cost to call USA
- Home Phone
- Cost to call USA
Cost to call USA
28-04-2014 11:22 AM
Tried to look, after page and page it's not simple or clear for the product i have what it'll cost
Anyone able to help
Anyone able to help
Message 1 of 7
(2,181 Views)
6 REPLIES 6
Re: Cost to call USA
28-04-2014 11:33 AM
It is here and depends on the package you are on http://www.plus.net/home-broadband/tariffs/#discount-countries
To summarise
The three tariffs are
Anytime International 300
Anytime
The rest - basically Weekends/Evening Weekends/No included calls
To summarise
Anytime
Message 2 of 7
(1,640 Views)
28-04-2014 11:38 AM
Quote Broadband & Home Phone packages
Plusnet Unlimited Fibre
Plusnet Line Only
Line rental
That's what I have.
So am i seeing this right as 12.60p per min to call the USA! My mobile is cheaper with EE
Message 3 of 7
(1,641 Views)
28-04-2014 11:43 AM
For evenings and weekends that is correct
Message 4 of 7
(1,641 Views)
28-04-2014 12:04 PM
Hi ,
You might want to have a look at using "access number", when dialling abroad from your landline, I have used them quite a few times, with no problems. and they are so much cheaper,
http://callchecker.moneysavingexpert.com/intcallchecker/usa/bt/easy
Starts from 0.51p/min
Regards
Mike
Regards
Mike
Message 5 of 7
(1,641 Views)
28-04-2014 1:10 PM
Hi lisapetewright,
Yes, that is correct. The standard rate is 18.30p during the Daytime and 12.60p during the Evening and Weekends.
Another option is to use Skype as this is free if the person you're calling has it installed as well and it's also possible to do video calls through it.
Message 6 of 7
(1,641 Views)
28-04-2014 2:57 PM
Message 7 of 7
(1,641 Views)
