Cost of phone calls
- Home Phone
- Re: Cost of phone calls
Cost of phone calls
20-12-2014 2:29 PM
According to what I can find on BT calls the cost per minute will depend on the following 3 number and in my case the numbers are 884.
I am with Plusnet for my phone line with anytime local calls free but clearly these calls will not be free so is there any I can find out the cost of these calls other than wait for my monthly bill from Plusnet.
20-12-2014 2:35 PM
20-12-2014 2:53 PM
0844-884 is not listed there. I suspect that the referred to list has not been updated since Ben T left.
This post in the thread - http://community.plus.net/forum/index.php/topic,115999.msg1001296.html#msg1001296 - delivers a practical approach...
0844 884 is tariff g6.
PlusNet's charge for this tariff can be found here - https://portal.plus.net/home-broadband/tariffs/
Destination : Setup fee - Daytime - Evening - Weekend
Specialised Service - g6 : 15.00 - 7.62 - 7.62 - 7.62
20-12-2014 2:59 PM
Quote 08448440444 Specialized Service - g6
20-12-2014 3:12 PM
I do not really want to turn this into a Christmas Pantomime... unless you insist..
Quote from: Oldjim Yes it is in reply 3
Unless Glenegales made a typo - Oh no it is not!
Quote from: gleneagles calls the cost per minute will depend on the following 3 number and in my case the numbers are 884.
Quote 08448730000 Specialized Service - g6
08448910321 Specialized Service - g10
884 is missing from the list; I looked up the tariff for this number on the BT tariffs link.
Kevin
20-12-2014 3:13 PM
20-12-2014 3:18 PM
You caused me to have to go back, look very hard and enlarge the list, less I had made the same error!
This does though challenge the merit of that post if it cannot be maintained as tariffs change.
20-12-2014 3:22 PM
20-12-2014 5:16 PM
From what I can see the cost is 6p per minute plus a possible set up cost.
My excuse for the error is down to trying to do too much at once and not double checking what I am doing.
Sorry.
20-12-2014 5:28 PM
