Cost of Line Rental Saver
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Cost of Line Rental Saver
03-06-2017 1:03 PM
Hi
LRS is about to go up from 29.6.17. My current one expires on 31.7.17. If I renew now before the price increase, will I be charged the current price of £185.88 until 31.7.18?
Thanks in advance.
Fixed! Go to the fix.
03-06-2017 1:09 PM
Hi @Cagney1994, that's correct. If you renew LRS before the price increase comes in to effect, you'll be purchasing it at the current rate for the 12 months following your current LRS expiring.
03-06-2017 6:07 PM
@HarryB - Brilliant. Thanks
on 16-06-2017 9:14 PM - last edited on 16-06-2017 10:00 PM by Mav
Hi Harry,
My existing LRS expires around 13-07-17 and I renewed in May @ £185.88
[CSA Removed] from Customer Service called today (16-06-17) to activate the new agreement. This is well in advance of when my old LRS is due to finish, effectively shortening the term from 12 months to 11. She was unable to confirm the period for which I was renewing. I was left with no option but to decline her 'activation' request.
Please explain. I'm confused and frustrated.
Moderator's note by Mike (Mav): CSA name removed as per Forum rules.
16-06-2017 9:20 PM
If you pay to renew your line rental saver before the current LRS expires, then it won't begin until that ends. Effectively, your line rental saver will be queued and will auto renew after the expiry.
I hope this helps clarify things.
16-06-2017 9:24 PM
Hi @5c1eb9d2
You can pay for your next 12 months of LRS up to 3 months in advance of your current LRS ending.
Once your current LRS ends. Your next 12 months (paid up front) will then commence
on 16-06-2017 9:46 PM - last edited on 16-06-2017 10:01 PM by Mav
Thank you for explaining that. I wish [CSA Removed] had said that and saved me all the frustration
- Home Phone
