Cost of Directory Enquiries.
baldrick
I needed to check a phone number. I dialled 118226 who's web site (118CAN) states that you can make up to 2 enquiries for 23.5p. PN have charged me 49p for 1. Any-one know why?
Also can any-one advise whether there a cheaper source that doesn't involve having to listen to adverts?
10 REPLIES 10
Oldjim
Fixes: 63
Re: Cost of Directory Enquiries.
pierre_pierre
its on the RH side of that busy page and free, and it works
nadger
That's the one I always use + my old BT registration still works.
alanf
118 CAN should have included the disclaimer that "calls from a BT land line cost x, calls from other providers may vary and that calls from mobiles may cost considerably more" as others do when giving out numbers on TV.
However...
BT classes 118226 as a dq57 fixed rate of 23p per call.
http://www.productsandservices.bt.com/consumer/consumerProducts/pdf/SpecialisedNos.pdf
Plusnet charges (or is supposed to charge) 25.30p per call to dq57 numbers.
http://www.plus.net/residential/tariffs/homephone.html
You seem to have experienced yet another foul up in the phone billing system.
Mand
You should have been charged a fixed fee for this call of 23p. I've raised a problem to get this investigated (ref 59842).
baldrick
Thanks Mand.
alanf
23p? Are you saying that the Plusnet list if tariffs is also incorrect? As I posted above the published rate is 25.3p per call.
Mand
25.3p is the pence per minute rate if the call is chargeable (the fixed fee only applies for the first minute, however most of these calls don't take longer than a minute).
alanf
Plusnet lists dq57 under "fixed fee calls" not under "Calls charged by fixed fee and Timed Duration (where the fixed fee is the charge for the first 60 seconds of the call, or part thereof, and the duration charge applies following the first 60 seconds)"
artmo
Aspiring Champion
I do as Jim does and use the BT website for all my directory enquires.  Works well.
