Constant junk calls beginning 0121 or 0120
- Home Phone
- Constant junk calls beginning 0121 or 0120
07-02-2018 10:57 AM
I wish there was a way I could block all calls starting with those numbers. PlusNet? And I'll take a chance on any genuine numbers not getting through.
Re: Constant junk calls beginning 0121 or 0120
07-02-2018 11:48 AM
Sorry to hear that.
As far as I'm aware you can't block individual area code.
I can see you've got the Plusnet Call protect enabled.
Have you been blocking the individual numbers using this?
07-02-2018 12:02 PM
Just for accuracy, 0121 is Birmingham. It and other certain other major cities have codes 01?1 with 7 further digits, whilst still more have 011?.
0120 is incomplete. The code should be 0120?.
07-02-2018 2:40 PM
Thanks Matt. I was asking more in hope than anything else. Yes, all identified numbers that are junk ALWAYS get added to my Call Protect list. But as you can guess the remaining 7 digit permutations after those two STD codes must run into thousands.
- Home Phone
