Con Con Con
- Home Phone
- Con Con Con
Con Con Con
13-08-2014 10:17 AM
I rang my parents number to let them know I had got home okay and I only rang once (ONCE) so it was never answered.
You seriously telling me PN charge 23p if you call a number and let it ring once!?
Re: Con Con Con
13-08-2014 10:18 AM
Re: Con Con Con
13-08-2014 10:19 AM
I can't change to unlimited calls for another month (unlike BT where you order it and it done in 24 hours like call features) but if this is going to be the case every time I might as well get that so it's cheaper
Re: Con Con Con
13-08-2014 10:51 AM
Quote from: Hairy If it was to a mobile, then yes as mobile calls are charged even if unanswered.
Eh
Re: Con Con Con
13-08-2014 11:07 AM
Re: Con Con Con
13-08-2014 11:15 AM
Re: Con Con Con
13-08-2014 11:19 AM
They may have had a device similar to my call blocker that drops any withheld numbers etc, that would explain the connection/drop.
Re: Con Con Con
13-08-2014 11:19 AM
Quote from: Chris I've just pulled out the raw call record we received for this and it shows that the call connected for a period, this is rounded up to the nearest minute. It's worth noting that a call can connect if any device, answering service/machine on the line picks up the call.
Oh well, your call record can say what it likes. I know what happened and what was done as I was there when I did it.
Im glad your call record is so precious to you (and not at all faulty - as it used to be all those years ago) . It's just cost you a customer on top of all the other reasons.
BT don't do this - so I'll go with them
As for the mobile bit - another con con con - again BT don't do this.
If you didn't offer cheap ass Broadband then you wouldn't need to shaft in other areas.
Re: Con Con Con
13-08-2014 11:23 AM
con con con
Re: Con Con Con
13-08-2014 11:36 AM
For the record (and being ex-PlusNET I would have thought you knew this) it is the RECEIVING phone network which generates the call answered signal to BTOR who then register the billable call. Those billing charges are then simply forwarded to PlusNET or which ever other virtual CP is using the BTOR network.
The CP (in this case PlusNET) has no role in determining if the call was or was not answered and therefore billable. I would recommend that the issue be raised with your parent's phone provider.
What might be relevant here is has your parent's phone number been migrated between suppliers - e.g. Sky or Talk Talk? There was a long thread in the phone forum in relation to this issue in respect of some mobiles. The research that I did at the time suggested that call answered signal could be erroneously generated at other provider's VoIP network boundaries. If I can find the post, I'll add a link.
You migrating away from PlusNET will not solve this problem, because the cause lay more with your parent's phone (or at least the call routing between BTOR and your parent's phone) than PlusNET.
Good luck,
Kevin
Re: Con Con Con
13-08-2014 12:00 PM
Re: Con Con Con
13-08-2014 2:00 PM
Re: Con Con Con
13-08-2014 2:52 PM
Personal attack and avoidance of swear filter removed.
Re: Con Con Con
13-08-2014 3:03 PM
This is something that certain mobile operators seem to charge for while others don't.
There was quite a long thread on this a few months ago. It seems some mobile operators mark the call as "connected" even when it isn't and the originating number then gets charged for this.
Re: Con Con Con
13-08-2014 3:42 PM
Old thread found - see here http://community.plus.net/forum/index.php/topic,127718.msg1113044.html#msg1113044 - it is a long thread enjoy!
I see that you made a contribution to the thread Pete (http://community.plus.net/forum/index.php/topic,127718.msg1114218.html#msg1114218).
Ben Trimble was investigating the matter before he left... wonder where he go to?
Kevin
