Compensation for no phone connection?
- Home Phone
- Compensation for no phone connection?
- « Previous
- Next »
Re: Compensation for no phone connection?
28-10-2011 7:20 PM
My dial tone has returned as has my broadband connection. It’s a little wobbly and the connection has dropped a couple of times so I’m keeping an eye on it but at least its up.
Many thanks for your assistance.
31-10-2011 10:50 AM
31-10-2011 10:51 AM
31-10-2011 11:00 AM
31-10-2011 11:10 AM
31-10-2011 4:03 PM
31-10-2011 4:44 PM
I'm going to run a line check to see if I can increase the speed profile and I'll make sure your'e credited for the period of down time.
31-10-2011 4:49 PM
05-11-2011 4:19 PM
I have had no phone connection for the last 24hrs. Joined plusnet 3 dys ago. Try as I may to get some explanation for this I am at a loss to know why this is happening and have had no satisfactory explanation. From all accounts this can go on for several days. I'm so disgusted that I am already thinking of leaving Plusnet and take the financial penalty.
05-11-2011 4:43 PM
Your answer to the above will dictate how you go about raising a fault.
If you have both your broadband and telephone with Plusnet, then it's Plusnet you raise a fault with.
However, if you have only your broadband with Plusnet, you will need to raise a fault with your telecoms provider.
Hope this helps.
07-11-2011 10:43 AM
- « Previous
- Next »
- Home Phone
