Charged for a call I didn't make
SpicyPineapple
Hi. My bill is charging me 50p for a call to 123. I did not make the call, nor would I ever ring the speaking clock. How can I fix this please and also make sure it doesn't happen again?
20 REPLIES 20
Fixes: 307
Re: Charged for a call I didn't make
@SpicyPineapple This is a recurring problem. Phone engineers use the 123 number - incorrectly - when looking for spare pairs.
A PN Help team member should pick this up and arrange a refund of the 50p.
ClaudiaG23
Fixes: 25
Hi @SpicyPineapple I've popped a ticket onto your account regarding the charges.
You can view this here https://www.plus.net/wizard/?p=view_question&id=237189374
 Claudia Garner
Confuse123
I’ve been searching the forum for the same issue, but mine is far worst. I have over 60 calls to 123 which we did not make that lasted 1-2 seconds and seems to be concentrated across a few days in Oct but the first one appeared 31/8 which I did not notice and have paid by direct debit.
Can someone look into this and remove the charges as it is over £34!
It might still be happening as I’ve received an email from Plusnet that it is blowing my call credit limit….which is crazy when you come to think about it.
James30
Fixes: 32
@Confuse123 - Thanks for reaching out to me on here, I'm struggling to find your account with the username you have on the forums, I'll send you a PM so you can reply to that with some details. Cheers
James - Plusnet Sheffield
RealAleMadrid
Aspiring Hero
Fixes: 62
@Confuse123  If you are seeing a lot of calls to 123 it is unlikely to be caused by engineers dialling the number. There is another possible cause which is a line fault where repetitive disconnections cause invalid numbers to be dialled. Can you see any other unexpected calls on your bill that look wrong.  They will generally all have low digits i.e. 0, 1, 2, 3, and maybe a few higher. If this is the case you will need Plusnet to raise a phone fault.
Fixes: 103
@RealAleMadrid
" a line fault where repetitive disconnections cause invalid numbers to be dialled. Can you see any other unexpected calls on your bill that look wrong.  They will generally all have low digits i.e. 0, 1, 2, 3,"
This is a throw back to pulse dialling, it needs to be noted on a UK rotary dial phone the numbers are (anti clockwise) 1 to 0, 1 has the shortest travel creating one pulse, 0 has the furthest travel creating 10 pulses. This makes a faulty line dialling 123 likely.
RealAleMadrid
Aspiring Hero
Fixes: 62
@Dan_the_Van  My mistake, 0 would not be one of the false digits dialled.🙄
Confuse123
None, all are to 123 months et the listing of calls also we don’t even have a phone connected to the line as it is purely for broadband.
Wonder whether there is a way to have no phone line or have zero credit given to phone calls so there is no way Plusnet will bill us for calls like this…
Fixes: 103
@Confuse123
Plusnet offer a "Fibre" product not to be confused with "Full Fibre"
Fibre is broadband over copper with no landline phone service
Confuse123
Hi James,
Any luck? Did you get my message with my username? Thanks
James30
Fixes: 32
@Confuse123 - Sorry for the delay, I've ran a test and found an external fault so have raised it off to Openreach. The faults ticket is here @ https://www.plus.net/wizard/?p=view_question&id=237480886 but the estimated repair date is 12/10/23, once the issue is resolved I'll be able to look at the bill for the calls to "123".
Confuse123
Thanks James, please keep me posted.
willcutforth
Fixes: 113
Hey there @Confuse123 it should be resolved now! Is that the case from your end?
 Will Cutforth
James30
Fixes: 32
@Confuse123 I'll check back with you on Tuesday to see if there are anymore 123 talking clocks dialed now the fault has been fixed. Just an FYI it's 14:26PM. Jokes aside I'll get the charged sorted on Tuesday if we're in the clear.
