Changing to PN phone questions?
- Home Phone
- Changing to PN phone questions?
07-01-2015 7:46 PM
Hello,
I am thinking of changing from BT to Plusnet phone line.
My questions is at the moment my mother is paying BT for the phone and I am paying Plusnet for broadband.
Will this cause any problems if I want to change both to my name?
Also can I find out whether I can keep the same phone number before changing?
Message 1 of 6
(1,130 Views)
5 REPLIES 5
Re: Changing to PN phone questions?
08-01-2015 1:10 PM
Hi davec940,
Both of these should be completely fine.
The only thing foreseeable that could cause you a problem is if you and still contractually bound by BT so I recommend getting Mrs davec940 to contact them to ensure that they're aware of what's happening.
Matty
Matty
Message 2 of 6
(523 Views)
08-01-2015 4:11 PM
Hello Matty,
The phone has been with BT for 10+ plus years so I assume there should be no problem with being contractually bound by BT?
Message 3 of 6
(523 Views)
08-01-2015 4:18 PM
Message 4 of 6
(523 Views)
11-01-2015 9:44 AM
Theres always the opportunity of a contract extension for a cheaper price
Message 5 of 6
(523 Views)
12-01-2015 11:49 AM
Definitely worth checking first but aside from that there should be no problems at all.
Warm regards
Sharon
Warm regards
Sharon
Message 6 of 6
(523 Views)
- Home Phone
