Changing to Broadband only and no phone
Batfrog
Re: Changing to Broadband only and no phone
Yes indeed I am. I have been experimenting with VOIP for a little while.It's as I said my main objection to FTTP is the logistics inside the house.
Thanks again
Fixes: 334
@MisterW Even though FTTC SoGEA is shown as available?
Batfrog
Hmm' I guess the only way to find out is to ring Plusnet !
Fixes: 532
https://www.openreach.co.uk/cpportal/products/the-all-ip-programme/stopsell-updates
About halfway down
The section headed
FTTP Priority Exchange Stop Sell
What does this mean for me?
These rules will only apply to premises in an FTTP Priority Exchange where FTTP is available. In these instances, FTTP will be the only product you can buy.  This means WLR3 Analogue, ISDN 2, ISDN 30, SMPF, MPF, FTTC, Narrowband Line Share, Classic, Gfast, SOGfast, SOGEA and SOTAP will be unavailable.
Batfrog
' Sugar !!! Looks like it'l have to be FTTP
Thanks all
Fixes: 89
@Batfrog
Try PlusNet Customer Options Team on 0800 013 2632
As to your Router with FTTP - as it's connected by an ethernet cable it can go where ever you're happy running cable. As the the ONT, there is a bit of lee way as to where it goes but it does need a power source.
The last line of the Checker results image you posted cleary show FTTP has priority over other porducts if available.
bgiles
@Batfrog
My exchange wasn't FTTP Priority, as can be seen from the my BT Availability Checker in message 16.
This however didn't prevent the Plusnet CS wanting to push me down the FTTP route, which I declined.
You don't say if you're currently on ADSL or FTTC?
@MisterW
Is it possible that FTTC to SoGEA is not classed as NEW product, as all that's involved is disconnecting the PSTN side (OSLAM & Filter)?
Plusnet SoGEA
DrayTek Vigor2762 VoIP Router
Fixes: 532
@bgiles  AIUI it applies to ANY new order on Openreach. FTTC to SOGEA still involves an Openreach order. The only thing that doesn't, is a recontract on the same product.
