Change of home phone plan not showing up
daveofthedead
I subscribed to the "Unlimited UK & Mobile Calls" plan nearly a month ago and got a confirmation saying "Your new package will be active on: 28th October 2022."
However, it's not showing up in my account and there is an error message. Quote:
"An error has occurred
You can't change your products for the moment, you already have a product change in progress."
I've tried calling but just get stuck on hold for ages. Anything else I can try?
6 REPLIES 6
Fixes: 237
Re: Change of home phone plan not showing up
Lines are busy at the moment ... staff are in here intermittently and should pick up your request here directly.
daveofthedead
OK, thanks.
willcutforth
Fixes: 113
I'm here to the rescue @daveofthedead I have added a ticket on https://www.plus.net/wizard/?p=view_question&id=229320932 to discuss this. Let me know if you can view it.
 Will Cutforth
daveofthedead
Hi Will,
Thanks, I can see the ticket. Thanks for the update.
Dave
willcutforth
Fixes: 113
Glad you can Smiley get back to me if you need anything else.
 Will Cutforth
willcutforth
Fixes: 113
This should be sorted now @daveofthedead Smiley
 Will Cutforth
