Change home phone
lilyroo
Change home phone
How can I change my home phone number
8 REPLIES 8
198kHz
Fixes: 41
Re: Change home phone
@lilyroo Welcome to the forum.  🙂
When one of the Plusnet Help Team spot this thread they'll start the process for you.
It'll cost £36.63, as detailed in the Plusnet price guide for residential products .
Scroll down to Plusnet Phone price guide, then click on Connection charges and other charges for Plusnet Phone services.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
adam945
Fixes: 113
Hello @lilyroo, if you're happy with the charge detailed above, please let me know and I'll get a ticket raised on your account. Smiley
Bare in mind, if you're receiving nuisance calls, it might be worth adding your number to the TPS service first to see if that helps.
 Adam
 Plusnet Help Team - Leeds
lilyroo
Yes I'm happy with the charge thanks
adam945
Fixes: 113
I've just created a ticket on your account, give me a nudge when you've responded and I'll get the renumber processed. Smiley
 Adam
lilyroo
OK thanks I am OK with the charge to change my home phone number
Fixes: 161
Did you reply to the ticket? Instruction / acknowledgment cannot be made via the forum - it must be via your account using the ticket link a couple of posts back.
lilyroo
I have responded to the text message that was sent
adam945
Fixes: 113
That's all been sorted out for you @lilyroo, your new number should be active on your line by the end of the day tomorrow. Smiley
 Adam
