Change Of Calls Package
thedouth
On the 27th January I made an order to change my call package to anytime calls. I had an email confirming receipt of the package and that it will be complete on January 30th . If I go on to my account it still says in progress. If anyone from plusnet reads this can they please look in to this for me and get back to me
5 REPLIES 5
Fixes: 378
Re: Change Of Calls Package
@thedouth When is your next invoice due? This sort of change takes effect from the start of the next charging period.
thedouth
The next bill is 21st February, so do you think its best to wait until then . Not make any daytime calls until then ?
Fixes: 378
Correct - your new package will kick in on the 22nd.
thedouth
Thank you for getting back to me
Fixes: 1,662
I can try to put the change through instantly for you.
Would you be able to drop me a reply onto the ticket which I've created here?
I'll then pick it up for you. I'm in the office until 5pm today and 9am to 5pm tomorrow.
