Cancel phone Service
tolmie35
Hi there, I'm just wondering if I'm able to cancel my phone service and keep everything else or am I tied into this.
6 REPLIES 6
Oldjim
Fixes: 63
Re: Cancel phone Service
If you cancel the phone everything will cease unless you are on the FTTP trial
If you migrate the phone to another supplier (non LLU) the broadband will stay but with a cost increase
If you migrate the phone to a LLU supplier the likelihood is that the broadband will cease
HarryB
Fixes: 256
There's not really much more I can say further to Oldjim's post, he seems to have covered the options.
 Harry Beesley
tolmie35
what, if i can everthing will cease, why? I dont want to cancel my line, i simply dont require my call anytime package, this should have nothing to do with my line rental etc.
HarryB
Fixes: 256
Ah right. You can certainly remove Anytime calls.
From your original post, it sounded as those you wanted to cease the phone service, not just drop the call plan.
You should be able to change your call plan here: https://www.plus.net/upgrade_process.html (Login required)
 Harry Beesley
tolmie35
Sorry guys if I wasnt clear from that start but thanks for the reply Harry, I guess I'll need to phone later to do this.
HarryB
Fixes: 256
Or you can change the package via the member centre using the link provided in my previous response:
The first page should give you options for broadband, which assuming you don't want to make any changes, you just continue through on to the phone section Thumbs_Up
 Harry Beesley
