Cancel phone Service
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Cancel phone Service
02-11-2016 1:05 PM
Hi there, I'm just wondering if I'm able to cancel my phone service and keep everything else or am I tied into this.
Fixed! Go to the fix.
02-11-2016 1:10 PM - edited 02-11-2016 1:10 PM
If you cancel the phone everything will cease unless you are on the FTTP trial
If you migrate the phone to another supplier (non LLU) the broadband will stay but with a cost increase
If you migrate the phone to a LLU supplier the likelihood is that the broadband will cease
02-11-2016 1:18 PM
02-11-2016 1:34 PM
what, if i can everthing will cease, why? I dont want to cancel my line, i simply dont require my call anytime package, this should have nothing to do with my line rental etc.
02-11-2016 1:39 PM
Ah right. You can certainly remove Anytime calls.
From your original post, it sounded as those you wanted to cease the phone service, not just drop the call plan.
You should be able to change your call plan here: https://www.plus.net/upgrade_process.html (Login required)
02-11-2016 1:42 PM
Sorry guys if I wasnt clear from that start but thanks for the reply Harry, I guess I'll need to phone later to do this.
02-11-2016 1:44 PM
Or you can change the package via the member centre using the link provided in my previous response:
The first page should give you options for broadband, which assuming you don't want to make any changes, you just continue through on to the phone section
