Can't use BT 151 to interrogate calls on BT Graphite phone
- Home Phone
- Re: Can't use BT 151 to interrogate calls on BT Gr...
20-09-2016 4:22 PM
Re: Can't use BT 151 to interrogate calls on BT Graphite phone
20-09-2016 11:14 PM
Isn't that a BT facility? Not extended to PlusNet lines.
26-09-2016 3:57 PM
Welcome to the community forums @melfishdes
Although admittedly I'm not 100% sure what you're referring to. If it's a feature built in to the handset, does it require caller display to function?
You don't appear to have caller display on your account, however if this is something you'd want to add, you can do so here: https://www.plus.net/plustalk/index.php?page=wlr_add_call_features
I hope this helps.
26-09-2016 7:25 PM
You can dial 0800 800 151 from a PlusNet line and that will get you through to the BT help system if you are ringing about another line which is with BT but this is no good to you if it's a PlusNet line you need help with.
1471 gives you the last number dialled and if it's enabled on your account 1571 will get you the answering service.
17070 will get you the BT line test facility to identify the number, quiet line test etc.
- Home Phone
