Can't download phone log in CSV format
peter6000
Last month (early September), the "new" billing system was in place and the CSV format had changed and had teething problems. This month (which is delayed, so it's like a month and a half since last billing), I try to download the CSV phone log and I get no data... just the column headings.
This is not very good. This is a very simple task. Why are you failing?
Peter.
3 REPLIES 3
deank
Fixes: 14
Re: Can't download phone log in CSV format
Hi @peter6000
Sorry to hear that you are having issues. I will pass this on to our back end team for you.
peter6000
UPDATE: Apologies!! I was looking in the *old* place where the call log was downloaded. I've found it now.
*serves me right for being stroppy! 😉
deank
Fixes: 14
No worries at all, glad to hear you found it in the end. If you have any further queries, please let us know.
