Can't change business number to home number when we move 4 streets away?
MeepMeep
Plusnet business support say I can't switch my business phone number to our home number when our lease ends as they're on different exchanges.
I've checked online & I don't believe it's the case as they're so close together.
It's literally 4 streets away & the same distance between the telephone exchange.
We need to keep our landline number for the business & have an account at home and at our premises so it shouldn't be an issue.
Any advice?
Thanks.
6 REPLIES 6
Re: Can't change business number to home number when we move 4 streets away?
Hi This may help when you have entered your numbers click on the exchange and it will give the location details etc
Hope this helps
https://availability.samknows.com/broadband/exchange_search
MeepMeep
Yes that says its the same exchange also yet plusnet say otherwise.
@MeepMeep wrote:
Any advice?
Migrate your phone number to VoIP, then you can use the number wherever you are.
Fixes: 1,596
Welcome to the community forums @MeepMeep
Both addresses seem to be on the same exchange so I don't see any reason why we won't be able to move your telephone number over to your new address. I can see that you've since called us and we've arranged that.
Apologies if you were given different advice before. Let us know how your move goes.
198kHz
Fixes: 41
I trust that the business support advisor has been 'educated'. Ticked_off
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Fixes: 1,596
As always I'm happy to pass feedback on.
