Can dial out on home phone but cannot receive calls
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Can dial out on home phone but cannot receive ...
14-10-2018 11:01 AM
Can't receive incoming calls. Sometime rings once then just cuts off. I have removed all cables and used a corded phone into the master socket still not working. Done the phone problems page and done a phone line test. That just comes up with "Opps there is a problem" Tried phoning but 60 minuetes wait, chat not working.
Fixed! Go to the fix.
Re: Can dial out on home phone but cannot receive calls
14-10-2018 11:47 AM
While you wait for a staff member to pop by, you can do a quick check to see if the phone test did raise a fault (It sometimes says it has failed but does raise a fault report)
Log on to https://www.plus.net/wizard/?p=search and it will show any open tickets. If the phone tester managed to log a fault, the resulting ticket will show as open here.
14-10-2018 12:01 PM
No fault logged.
15-10-2018 11:48 AM
Hi @jtr,
I'm sorry to hear that you're experiencing this issue. I've taken a look into your account today and I can see that you have since spoken to our Support Team regarding this and a fault ticket has been raised here.
If you have any further queries or issues that you would like to raise please let us know and we'll be happy to assist further.
18-10-2018 9:01 AM
Fault found in outside cable coming through the wall into lounge.
All working ok now.
18-10-2018 2:57 PM
- Home Phone
