Can I use 18185?
- Home Phone
- Can I use 18185?
Can I use 18185?
07-03-2009 12:51 PM
I'm thinking of changing to PN Home Phone when my present BT contract ends this month. Will I still be able to use 18185 for dialling mobiles in the US?
Message 1 of 6
(2,402 Views)
5 REPLIES 5
Re: Can I use 18185?
07-03-2009 1:13 PM
Not heard of that. How does it work MM?
Message 2 of 6
(517 Views)
07-03-2009 1:43 PM
You can use it as PN don't block call overrides, see this thread
Message 3 of 6
(517 Views)
07-03-2009 2:12 PM
Thanks for that, adiewoo, it's reassuring. I remember override providers were discussed last September (as your thread explains), but I just wanted to make sure PN still allows them. Let's hope nothing changes!
Message 4 of 6
(517 Views)
07-03-2009 2:27 PM
The simple answer is Yes. As you're already registered, just carry on as normal.
Message 5 of 6
(517 Views)
07-03-2009 4:24 PM
Great, I'll make the change!
Message 6 of 6
(517 Views)
